No turn signals
69XR7RestoMod
No turn signals
Post by 69XR7RestoMod » 12 Dec 2017, 17:52
Hoping I can get some help, as I'm not sure where too start looking. When I turn on my turn signals, I hear the flasher clicking, but have no dash indicator or turn signals front or rear.
I'm running all incandescent lights, original flasher box in trunk and a solid state flasher.
Every light on the car works, headlights, tail lights, marker lights, brake lights and hazards all function correctly.
When I push the brake, all the tail lights come on until I turn on one of the signals, then that side goes dark instead of flashing.
I did check the connections on the sequencer box and they all appear to be dry and tight.
so where do I go next?
1969 XR-7 Restomod 408ci 483HP/523TQ, FiTech, TKO-600
rcode
Re: No turn signals
Post by rcode » 12 Dec 2017, 19:40
Would appear to be a grounding issue..
69 XR7 CJ Triple R San Jose built
Star LM Glendale, CA
03 Cobra (ordered new)
69XR7RestoMod
Re: No turn signals
Post by 69XR7RestoMod » 12 Dec 2017, 20:48
How do you figure? Grounding where?
rcode
Re: No turn signals
Post by rcode » 13 Dec 2017, 20:40
Either at the sequencer box or internally.
rcode
PerryR
Re: No turn signals
Post by PerryR » 15 Dec 2017, 15:24
Could be a bad connection in the turn signal switch.
69XR7RestoMod
Re: No turn signals
Post by 69XR7RestoMod » 15 Dec 2017, 16:09
So I happened to have an old 552 flasher laying around. I replaced the electronic flasher with the 552 and the turn signals work fine (actually as well as they can with a 552).
So I just need to order a new electronic flasher. Apparently, even though it wasn't flashing the lights, it still clicks and sounds like it works.
rcode
Re: No turn signals
Post by rcode » 16 Dec 2017, 10:25
Good to know. Always a help when someone posts a fix!
