Fuel Sender
sfhess
Re: Fuel Sender
#11
Post by sfhess »
Don, your catalog listing for 69-70 senders say they are for a 16-gallon tank. Fuel capacity for these is 20 gallons, 22 for a 70 without the evaporative emissions stuff.
Don Rush
Contact:
Re: Fuel Sender
#12
Post by Don Rush »
Yes, I will get them dialed in. My data input guy misses stuff from time to time. Good eye!
leonbray
Re: Fuel Sender
#13
Post by leonbray »
Royce wrote:Leon that would be a minor bending of the wire that holds the float. I don't use the reproduction sender without comparing it to an original and tweaking it to match exactly. Electrically the variable resistor (rheostat) is identical in the repros.
leonbray wrote:
Royce wrote:No, and I don't know why this is because the Thunderbird folks have a good reasonably priced sender unit with low fuel available from any T Bird part supplier.
In any case, you can buy the T Bird sender and swap the important parts (thermistor, sending unit, filter sock, and float) to rebuild your original cheaply. Click here to see the T Bird unit that you need to buy:
Royce.
Do you know if the sender unit is correct for Cougar gauge. The repro Mustang one doesn't read correctly on the three gauges I have tested. Mustang one goes full ok then drops to the empty mark (before the red area) when the tank is half full
If it shows empty when the tank is half full wouldn't it only show half when the tank is full? Mustang repro senders were tested out of the car
Designed to be driven
sfhess
Re: Fuel Sender
#14
Post by sfhess »
I have a 22-gallon 70 tank in my 69, using the 69 (20-gal) sender. The gauge stays on FULL for a long time......
Royce
Re: Fuel Sender
#15
Post by Royce »
You must have got a bad one if that is the case. The Mustang repro senders are of course the same as standard Cougar senders, and the reproductions are just as good as the originals from my experience. Good product, I think Scott Drake is the only source.
leonbray wrote:
Royce.
XR7-G Registrar
Don Rush
Contact:
Re: Fuel Sender
#16
Post by Don Rush »
No, there are at least 2 suppliers for the single prong sending unit, ACP being one of them and I believe carpenter being the other and yes Drake does repackage. We get a lot of returns on repro sending units, less now than years past but they still are not as good of quality as FoMoCo units.
sjrdcr
Re: Fuel Sender
#17
Post by sjrdcr »
I had a similar experience with fuel senders on my 1968 1/2 Cobra Jet Mustang. After installing two repro senders, both of which would read half full when the tank was full (one of which was a Scott Drake), I finally bought an NOS Ford original which of course worked perfectly. These were the single stud units as that car did not have the low fuel warning option. I have high hopes for your low fuel warning repro unit Don. Thanks for all you do.
Don Rush
Contact:
Re: Fuel Sender
#18
Post by Don Rush »
rcode
Re: Fuel Sender
#19
Post by rcode »
Ordered mine yesterday with the low fuel warning. Looking forward to having everything back to normal.
rcode
69 XR7 CJ Black plate Triple R car, original selling dealer:
Star Lincoln Mercury, Glendale, CA
03 Cobra (ordered new)
LaBelle Ford LaBelle, Fl
"Tonight, We Ride"!
1969XR7Vert
Re: Fuel Sender
#20
Post by 1969XR7Vert »
rcode wrote:Ordered mine yesterday with the low fuel warning. Looking forward to having everything back to normal.
rcode
It is great that WCCC has gotten quality repro's (better than OEM actually with stainless construction). A Cougar reproduction product that is long overdue.
I want to mention however that "back to normal" for this sub-system means annoying flashing of the LF lamp at the low fuel threshold. Only the Electronic Low Fuel Indicator (ELFI) kit corrects this condition with significant hysteresis at threshold, effectively eliminating flashing. With the ELFI, the LF condition must exist for ~1 minute before the LF lamp will be illuminated. Similarly, the lamp will not go out until the LF condition is no longer present for ~1 minute (ie. more fuel is put into the tank).
Unlimited technical support is also provided with the purchase of an ELFI kit.
Disclosure: I am the designer, manufacturer and seller of the ELFI kits. WCCC and NPD also sell them (but I have the best deal on them!).
Thanks WCCC for all you do for the Cougar owner, we appreciate it!
