1967 390 GT (with smog) belt routing help needed
Don Rush
Contact:
#1
Post by Don Rush »
Anybody have some good pics / diagram of the correct belt routing on a CA DSO 390? This has the 2 shiv alternator pulley and no ac. Trying to get the car letter correct and I rarely get my hands on a 67 with correct smog still in place.
Here is what it should look like with AC. Pretty convoluted!
https://secure.cougarpartscatalog.com/c7ae-9b452-a.html
BossElim69
Re: 1967 390 GT (with smog) belt routing help needed
#2
Post by BossElim69 »
Mine has AC so it doesn’t go around the water pump. Your smog belt pulley will go on the water pump vs ac pump. Water pump will be three grooves. So would just go around the outer groove on both water pump and crank and round the emission pump which will adjust to tighten the belt. My AC pump is removed from the car right now. You should have the same crank pulley as an AC car.
Brian Carpenter, President CATS classic Cougar club
67 Cougar road course racer
67 Cougar project car
67 Cougar GT
68 XR7-G trailer queen restoration.
68 Restomod
69 Boss 302 Eliminator
69 XR7 390 survivor
69 XR7 428CJ 4spd
69 standard convertible
70 Boss 302 Mustang
1993 Harley Davidson
2004 F250 diesel
2004 Jeep Overland 4.7L H.O.
78 Ford F 150 Ranger
08 Cobalt SS
PacificaXR7GT
Supporting Member
Supporting Member
#3
Post by PacificaXR7GT »
Unsure how/if it differs on a 67, but on my 68 GT with power steering and without AC the two alternator belts go around crank and water pump on the two sheaves closer to the engine. The power steering runs on the outermost sheave of the crank pulley. The smog pump runs on the outermost sheave of the water pump pulley.
Steve
CCOA #9998
1968 XR7 GT 4 speed - Augusta Green / Dark Ivy Gold
preaction
#4
Post by preaction »
Don there is a pic of this set up in a 67 engine assembly manual it also lists the correct pulley engineering numbers.
67 XR7 6.5 liter auto AC tilt pdb ps thermactor vinyl roof console SS wheels lime frost
preaction
#5
Post by preaction »
I only have pics of an A/C car.
J_Speegle
#6
Post by J_Speegle »
Don Rush wrote:
18 Oct 2019, 10:58
Engine assembly manual reprints have a diagram on page 97. Would post but respecting copywrite
Basically four belts according to the diagram
Thermactor to water pumper - front most section
Alternator to water pump and crank - two inner most on both - duel belts
PS to crank - forward most section
Hope this helps
Don Rush
Contact:
#7
Post by Don Rush »
Our confusion on what is seen on page 97 is that the PS pump in no way way aligned with the third groove. It would have to be shimmed out substantially more than what the factory spacer would accomplish.
https://secure.cougarpartscatalog.com/c ... attribs=75
The reason we are piecing this together is that it had an aftermarket ac system on it with 4 grooves on the crank, spacers on the brackets and all sorts of deviations.
68 hertz
#8
Post by 68 hertz »
Possibly the offset like the 80B ?
Randy ,Syracuse NY
68 hertz
#9
Post by 68 hertz »
Sorry ,offset pulley 80B
Randy ,Syracuse NY
Royce
#10
Post by Royce »
Yes but larger diameter than the 80B. Don the MPC will list all the pulley diameters. I have a '67 PS pulley, it's an "outie" and the one in your pictures is an "innie" as would be used with AC. An 80B would work it's just not quite as big in diameter as the proper one.
68 hertz wrote:
18 Oct 2019, 15:37
XR7-G Registrar
