Vacuum motor repair options?
428cougarguy
Post by 428cougarguy »
I need a working 1969-1970 headlight actuation vacuum motor. Is critter creek the only option?
Sorry but I just can't afford $685+shipping. :shock: I have bought entire parts cars for less.
I have several core actuators, but none seem to be able to pull in both directions.
Thanks, Scott Taylor
Re: Vacuum motor repair options?
Post by Mike_B_SVT »
Yeah, for $700 I can put a LOT of man-hours and materials into figuring out how to restore one. Then I can pocket the shipping money I saved >.>
I have a few trashed ones as well that I've thought of tearing apart and trying to rebuild. I've put quite a bit of thought into it, but I just haven't put any time into actually doing it. Hmm... maybe a good side business opportunity :think:
Seriously though, it's metal and rubber. How difficult can it be to fix one if you really put your mind to it? Last I heard, WCCC is making the upper seal and accordian boot. So all you need to do is gently pry one open. Find a suitable rubber material to replace the inner diaphragm. Repair / replace said diaphragm (including remounting the shaft and associated components). Gently pinch it all back together.
And if you have it apart and broken into the basic pieces, why not send the metal cannister halves to the plater and have them redo the original "olive drab" plating instead of using spray paint on it. Or order the materials and plate it yourself, if you're so inclined.
I think the hardest part will be opening the pinch seal without distorting the metal too much, and then pinching it closed again and making it look presentable.
Olive Drab Finish_example.JPG (19.68 KiB) Viewed 759 times
BossElim69
Post by BossElim69 »
If your center diaphragm is good John's will rebuild it. Here is a link on how to check it. Won't help you out if it sucks air in both directions. His rebuilt won't include replacing the center diaphragm.
http://www.johnsclassiccougars.com/Sear ... sp?Cat=198
Brian Carpenter, President CATS classic Cougar club
67 Cougar road course racer
67 Cougar project car
67 Cougar GT
68 XR7-G trailer queen restoration.
68 Restomod
69 Boss 302 Eliminator
69 XR7 390 survivor
69 XR7 428CJ 4spd
69 standard convertible
70 Boss 302 Mustang
1993 Harley Davidson
2004 F250 diesel
2004 Jeep Overland 4.7L H.O.
78 Ford F 150 Ranger
08 Cobalt SS
Al Bundy
Post by Al Bundy »
I wouldn’t really call that rebuilding. $120 gets you a new seal, and a new boot. Not very good value.
1974 Dodge Dart - daily driver
1963 Thunderbird Z code - raven black/red
1968 XR7 F code - diamond blue/blue
1968 XR7 J code - black/red
1968 J code - madras blue/aqua
1968 XR7 X code - lime frost/dark ivy gold
1968 GT-E XR7 W code prototype no. 500033 - cardinal red/black
canted 393
Post by canted 393 »
Here is a little bit better price on a critter creek rebuild option. https://www.npdlink.com/product/vacuum- ... 476/212887
Post by Royce »
Just buy the Corvette seal kit. Enlarge the holes and install. Easy.
https://www.ebay.com/itm/C3-Corvette-He ... 5214!US!-1
canted 393 wrote:
11 Sep 2019, 06:12
Is that actually olive drab plated? Or is it just painted? I thought Critter Creek painted theirs.
J_Speegle
Post by J_Speegle »
Mike_B_SVT wrote:
11 Sep 2019, 13:49
Looks like zinc dichromate - not even close to olive drab
Typically olive drab was used for clips and retainers and not for bolts or nuts
Post by Don Rush »
I have a critter creek unit in stock for less than the NPD price, correct kits coming soon!
https://secure.cougarpartscatalog.com/1 ... attribs=75
https://secure.cougarpartscatalog.com/d ... attribs=79
Post by CATHOUSE »
I have several used ones here that pass the test that Brian linked to in post #3. On some of them the accordion seal looks good too.
