And so it begins...
wawazat
Re: And so it begins...
#11
Post by wawazat » 10 Mar 2018, 13:54
Good luck with the installation! I installed the FiTech last summer.
1969 Cougar convertible restomod
JETEXAS
Contact:
#12
Post by JETEXAS » 11 Mar 2018, 21:05
I've been looking at the same kit. What are you doing on the fuel tank and return line?
DaveK
#13
Post by DaveK » 12 Mar 2018, 04:59
JETEXAS wrote:
11 Mar 2018, 21:05
My plan is to use the stock 3/8" line to feed the engine and I bought 25' of aluminum fuel line to run the return down the passenger side and use the tank drain as the return location.
DieselD
#14
Post by DieselD » 12 Mar 2018, 11:21
Nice! keep everyone post on the results if you dont mind! I have decided to go EFI just a matter of when and which system I want to run. Gotta get the car back together first before I worry about EFI.
1968 Standard, 302 2v, 3 speed.
DaveK
#15
Post by DaveK » 08 Apr 2018, 17:36
Here is how I mounted the fuel pump.
fuel pump mounted
pump mounted.jpg (57.07 KiB) Viewed 1026 times
ClawIt
#16
Post by ClawIt » 09 Apr 2018, 05:40
Until the thermostat opens you may not get the correct water temp.
DaveK
#17
Post by DaveK » 09 Apr 2018, 06:11
ClawIt wrote:
09 Apr 2018, 05:40
I know. I'm not worried about it.
Jan-O
#18
Post by Jan-O » 09 Apr 2018, 15:01
Isn't the thermostat installed backwards ?
DaveK
#19
Post by DaveK » 09 Apr 2018, 20:10
Jan-O wrote:
09 Apr 2018, 15:01
No. It is installed correctly. The focus on the picture makes it look like it is backwards.
ssava
Contact:
#20
Post by ssava » 10 Apr 2018, 05:37
This is cool.
Can I ask? What is the benefit of switching from carburetor to EFI?
"Esmerelda"
Franklin, TN
