67 gt 4 speed into a 68 x code cougar
A390gt
Post by A390gt » 07 Sep 2018, 17:15
I’m Getting ready to pull engine and c-6 out of the X and put in the 4speed and 3.55 locker in from my old 67gt.
My question are,
Is there a hydraulic clutch setup that works good with the 390 and top loader....Or should I just get all the bushings and rebuild the rod and spring system?
What’s a good clutch? I’m using The old flywheel, it looks ok just needs a resurface
Is there any detailed install instructions for a 4 speed? I kept everything from the 67 minus the pilot bushing for the last 30 years, I can usually feel my way through but if anything is out there it would be helpful
John
preaction
Re: 67 gt 4 speed into a 68 x code cougar
Post by preaction » 07 Sep 2018, 19:30
You may want to look at a new steel flywheel the original part is 50 years old and made of cast iron, looks good is a poor and unsafe standard to use for such a part.
67 XR7 6.5 liter auto AC tilt pdb ps thermactor vinyl roof console SS wheels lime frost
A390gt
Post by A390gt » 07 Sep 2018, 19:43
That’s an odd statement, I’ve had cars and trucks with original machined flywheels and never felt unsafe...
mo2872
Post by mo2872 » 11 Sep 2018, 07:58
Modern Driveline's "LF" hydraulic setup is very nice. I'm sure they could get you set up for the 390/Toploader somehow.
http://www.moderndriveline.com/
T3
Yup, that guy, the hooligan.
Somewhere out there is a tree, tirelessly producing oxygen so you can breathe. I think you owe it an apology.
