True or False
On what day in 1966 did the secret Cougar marketing program begin? April 1st, April Fools day. On what day in 1968 did the Cobra Jet 428 become available in the Cougar April 1st April Fools day. Is there a message in there somewhere? This is the place to find out.
Removing the thermactor components resulted in a HP gain
True
15
54%
False
13
46%
Total votes: 28
Al Bundy
True or False
Post by Al Bundy » 07 Mar 2019, 18:14
Enter your response.
1974 Dodge Dart - daily driver
1963 Thunderbird Z code - raven black/red
1968 XR7 F code - diamond blue/blue
1968 XR7 J code - black/red
1968 J code - madras blue/aqua
1968 XR7 X code - lime frost/dark ivy gold
1968 GT-E XR7 W code prototype no. 500033 - cardinal red/black
Cougars_R_Grr8
Re: True or False
Post by Cougars_R_Grr8 » 07 Mar 2019, 18:34
I would say True.
'68 Standard Cougar - 302 4v J Code 4 spd (1 of 536) *SOLD*
'73 F250 XLT Ranger - 390 *Also SOLD*
'63 F100 Stepside - *NEW PROJECT*
'14 Camaro SS vert
MercuryDon
Re: True or False
Post by MercuryDon » 08 Mar 2019, 01:13
I would say less weight and easier to work on !
68 427 GTE-XR7 Dk Blue/Dk Blue(1 of 3 Color/trim) C6 3.50TL
68 390 4V XR7G Dk Blue/Dk Blue w/Sunroof C6 3.25TL
69 428SCJ 4spd XR7 Conv't.White/Aqua 12K miles(1 of 1 with 4.30DL)
69 428CJ 4Spd Cyclone CJ Maroon/Blk 29K miles 3.50TL
68 390 4V Cyclone GT. Madras/White C6 3.00 (Introductory Show unit)
69 390 4Spd XR7 Sunroof Med.Lime/Dark Ivy 3.00
68 390 4V Cyclone GT White/Red C6 3.25
04 Cobra Conv't.4.6 DOHC Supercharged Blk/Grey 3.50TL
70 390 Javelin SST Big Bad Grn/Blk 700R4 4.10 Dana 44
98 Dakota R/T 5.9 Std Cab Blue/Grey(1 of 32) 3.91SG
71 Thunderbird 429 w/suicide doors Copper/Drk.Brn 2.75
06 Dodge SRT10. 11k miles 488 cube Viper V10. 505hp. 6 spd. 4.10SG
Re: True or False
Post by Royce » 08 Mar 2019, 07:55
I tried it at the Pure Stock Muscle Car Drags. It made zero difference in my ET or MPH by removing the belt from the smog pump. On the other hand, access to the spark plugs is easier with all of it removed. I am able to pull and replace the plugs with all of it in place. The smog system doubles the amount of time it takes to change plugs.
All that being said I have it installed and functional on both of my Cougars.
Re: True or False
Post by DieselD » 08 Mar 2019, 09:02
I doubt it has any real notable effect on hp but its sure in my way. I plan to get rid of mine one way or the other. Anyone have a line on the plugs they used when removing the pipes from the heads. IIRC from my research the plug size is 1/2"-20 and obliviously no one repros the delete plugs.
Al Bundy
Re: True or False
Post by Al Bundy » 08 Mar 2019, 10:27
Royce kind of spilled it and I've heard it from other sources as well. Although many removed the components for a HP boost, that was actually myth or at least so negligible it isn't worth mentioning. A few raise a good point about having less stuff in your way if you're doing a lot of tuning/tinkering.
PacificaXR7GT
Re: True or False
Post by PacificaXR7GT » 09 Mar 2019, 13:20
DieselD wrote:
08 Mar 2019, 09:02
Mine had hex head bolts in the holes. I took those out and installed these https://www.mustangsetc.com/cylinder-he ... -plugs-v8/. They aren't "correct" but at least don't call attention to themselves.
Steve
CCOA #9998
1968 XR7 GT 4 speed - Augusta Green / Dark Ivy Gold
Re: True or False
Post by DieselD » 06 Apr 2019, 10:16
PacificaXR7GT wrote:
09 Mar 2019, 13:20
DieselD wrote:
08 Mar 2019, 09:02
Just wanted to report back that these worked perfect. Saved me a ton of time running to hardware stores searching for the right one. I was expecting a fight getting the old smog tubes out of the heads but they came out pretty easy. These plugs worked great and I’m stoked to have all that smog crap out of my way. Now I just need to find the correct non smog alternator bracket.
