Rotisserie restoration
Ransom985
New Member
#1
Post by Ransom985 » 12 Aug 2018, 16:32
Afternoon all,
I have a question. This is my first vehicle restoration, I have floor pans and torque box amongst a multitude of other items to repair, restore. The vehicle is a 67 Cougar which is pretty much stripped down except for rear axle yet to come out. I'm thinking about putting the vehicle on a rotisserie, the main question I have is can the floor pans and torque boxes be replaced when the vehicle in on the rotisserie or should I replace these items prior to mounting the vehicle on the rotisserie (my mind tells me I should do it prior, but the question still rattles round in my head).
all suggestions welcome!
Thanks!!
thunderchero
Re: Rotisserie restoration
#2
Post by thunderchero » 12 Aug 2018, 19:50
when doing major metal replacement like that you must weld in temporary supports so unibody does not collapse. These supports will stiffen body while panels are being replaced. So if you get enough supports in the proper places you could use a rotisserie during panel replacement.
But it is also good idea to take as many frame/panel placement measurements as you can before you start any disassembly or start metal removal.
I miss hearing my kittens roaring....
1972 Comet GT red/black interior 302 auto (1979)
1970 Cougar standard pastel blue/blue interior, (1979-81)
1970 Cougar standard competition gold/black interior (1981-1984)
1970 Cougar XR7 convertible pastel blue/blue interior w/power windows (1983-1989)
1969 Sunroof Eliminators Hertz-Rent-A-Racer (1984-1985)
1970 Cougar standard convertible competition gold/dark ginger interior (1984-1985)
1989 Capri convertible/hardtop (1989-1995)
1995 T-bird LX police interceptor 4.6 (1995-2004)
1964 Ranchero deluxe (1999-) in-progress resto-mod
2004 Mazda 3 (2004-2017)
2017 Chevy Cruize (2017-)
J_Speegle
#3
Post by J_Speegle » 12 Aug 2018, 20:59
Might want to find someone that has a frame machine instead to hold all the other points in place or to establish the rest of the body back to their original locations before you install new panels. Rotisserie can't do that
Ransom985
New Member
#4
Post by Ransom985 » 13 Aug 2018, 06:57
Thanks for the info, This helps me immensely
tdz16
#5
Post by tdz16 » 20 Aug 2018, 15:01
I’d definitely do your panel and torque box work off the rotisserie while on multiple (4-8) jack stands or better yet, a chassis jig. I’ve got a rotisserie that I picked up a few months ago I’m dying to get the car on but for the time being while I chop and repair major pieces I’m leveled on jack stands and have pages worth of measurements written down in a notebook so I can match after. I haven’t welded in any supports yet because I’ve tried to plan each repair so that other parts remain supported. So far, so good. Good luck with your restoration!
-Tom
ccarney69
#6
Post by ccarney69 » 20 Aug 2018, 22:40
Do the metalwork before you put the car on a rotisserie.
1968 GT-E 427 Standard Nordic Blue/Black Décor, driver
1969 XR7 R Code 4 Speed Yellow/Black Top Black Interior, current project no.1
1969 XR7 Q Code C6 Green/Black Top Dark Ivy Green Interior, current project no. 2
CCOA #8275
MACC
