Emblem restoration
halbey
Emblem restoration
#1
Post by halbey » 02 May 2018, 23:11
I am wondering what my options are for the plastic covering on the fuel door emblem? I also understand that the plastic on the pillar emblems can be sanded and buffed out - mine still have good color but the sun has crinkled the finish and they have yellowed slightly. What grit sand paper would you start with and finish with? Best options for buffing after sanding? Any ideas would be welcomed.
1967 S Code
Re: Emblem restoration
#2
Post by 1967 S Code » 03 May 2018, 06:33
You can start with 1500 grit and then move to 3000 grit. Finish off with polishing compound. That's what I did with my gauge lenses.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
halbey
#3
Post by halbey » 03 May 2018, 09:00
1967 S Code, thank you. I hope I can get the plastic as clear as you did in the photos.
Sounnder
#4
Post by Sounnder » 07 May 2018, 17:50
67 S Code, are you doing the polishing by hand or you using a buffer on it? This is one of my next projects.
1969 Eliminator 390 / C-6
2017 Ram 6.7 2500 4x4 Limiited
1967 S Code
#5
Post by 1967 S Code » 07 May 2018, 19:09
Sounnder wrote:
07 May 2018, 17:50
I used a foam polishing ball attached to my drill. It’s visible in the last picture. It’s the dirty red color item just to the upper right of the lens.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
Sounnder
#6
Post by Sounnder » 08 May 2018, 18:46
Forgive my ignorance but I want to make sure I'm compleetly following. You are using 1500 and 3000 grit sand paper then using the polishing compound on the ball attachment, correct?
Thanks
Rick
DieselD
#7
Post by DieselD » 09 May 2018, 09:17
mine where not quite as bad and I was simply able to a good plastic buffing kit. I did not have any yellowing however. Also did my taillights and they came out looking new.
https://www.amazon.com/NOVUS-7100-Plast ... B002UCYRZU
1968 Standard, 302 2v, 3 speed.
1967 S Code
#8
Post by 1967 S Code » 09 May 2018, 21:20
Sounnder wrote:
08 May 2018, 18:46
Thanks
Rick
Rick that is correct. Wet sanded with 1500 then 3000 followed by the 3M polish on the polishing ball.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
