Fender extensions
blaineja
Fender extensions
Post by blaineja » 02 May 2018, 15:45
Another paint question for 69. Where the fender extensions gaskets for the front and rear painted over at the factory or not.
Thank You,
Jeff
1969 Yellow XR-7
Re: Fender extensions
Post by Don Rush » 02 May 2018, 16:06
No paint on the rubber. Look at KTL Restorations facebook site for pics on how to paint extensions.
67429merc
Post by 67429merc » 03 May 2018, 04:53
Jeff, if your car is a metallic color you should paint them mounted to the fenders/ and quarter panels. I place several washer on the mounting stud and install them. so you end up with a gap between the extension and the panel. by doing this your color match is spot on!! Them remove and install your rubber and trim.
67 standard(my first car) 428 4 speed
68 xr7
69 eliminator
70 eliminator
65 f100
70 mustang convertible
67 vw convertible
Post by Royce » 03 May 2018, 05:17
100% agree!
67429merc wrote:
03 May 2018, 04:53
