ivy gold vinyl dye
pellets4fuel
ivy gold vinyl dye
#1
Post by pellets4fuel » 22 Apr 2018, 06:35
So I thought I would ask after I typed in some search words, and got thousands of posts on hundreds of pages. I went to my local parts shop yesterday who mixes DuPont, (which I think got bought out) Anyway, we dug out the old book, and found the 2G code which if I recall right the DuPont number is 9266LH. He entered it into the computer, and came up empty.
Just wondering if anyone has a code from a more modern color, or alternative idea for getting some interior color mixed. He did a camera shot with whatever camera they use, and it didn't produce anything.
I need to change some black padded windlace for around the door openings to ivy, want to freshen the windshield pillar pads, spray a pair of the reproduction arm rests from that wrong dark green color, and perhaps freshen the door panels on my 67 standard. Thought I would tackle it myself.
I know John over there at JCC has dye in cans. Is that a better option?
Thanks,
David
David Siedschlag
#16306 1967 Lime Frost S-code, Ivy gold interior built 11-1-66
3.25 Limited slip, 4-speed. Courtesy lights, sports console, whisper-aire, AM-8track, deluxe belts.
1989 Toyota truck, woodgas powered
22re 4x4
neftali.rosado
Re: ivy gold vinyl dye
#2
Post by neftali.rosado » 25 Apr 2018, 22:13
I went with JCC for the paint and dye. I purchased Steering wheel ring and center at WCCC. The Console Pad picture was taken at night the color matches the rear panel and steering cap.
preaction
Supporting Member
Supporting Member
#3
Post by preaction » 25 Apr 2018, 22:36
Are you sure the steering column is painted Ivy too ?
67 XR7 6.5 liter auto AC tilt pdb ps thermactor vinyl roof console SS wheels lime frost
neftali.rosado
#4
Post by neftali.rosado » 25 Apr 2018, 23:10
Your right it is not. I was sent that color. I assumed it was what was available. It did seem a little darker to me. I questioned it as well. The colors look OK together but definitely off.
pellets4fuel
#5
Post by pellets4fuel » 27 Apr 2018, 17:12
I bought a couple cans of the L ivy in the SEM spray cans from NPD. I sprayed a little out on a crappy windshield pillar pad I have. It looks...well not green enough to match the other interior panels. I know over the years that light color can get dirty looking, and even after scrubbing it, will probably still tend too look a little darker than when it was new, but this new can stuff looks too "silvery" to me. Like I said not green enough. Kinda like the difference (I see at least on my screen) between the quarter panels above. Right one looks more silvery, the left one more green. Don't know what to do now.
David
David Siedschlag
22re 4x4
neftali.rosado
#6
Post by neftali.rosado » 27 Apr 2018, 21:22
I couldn't agree more. It definitely does not look the same. The panel on the left is the one I dyed and the old one is the right. Originally I just wanted to touch up my interior. The difference is so noticable I ended up painting/dying everything. I noticed that John sent me Light Ivy Gold Dye with Med Ivy Gold Paint for 64-66 Mustang. I was a little sceptical but I went with it. I got tired of going back and forth. At the end of the day I want a nice clean driver with decent power. I am not looking for a show car or a full restoration with exact original details. The console here looks like it has a little more gold because the picture was taken in the sun. It is the same paint and dye used on the panels and dash and they match great.
Dash Before.jpg (62.76 KiB) Viewed 347 times
Dash After.jpg (67.79 KiB) Viewed 347 times
Console 2.jpg (69.7 KiB) Viewed 347 times
Console 1.jpg (71.61 KiB) Viewed 347 times
CATHOUSE
#7
Post by CATHOUSE » 28 Apr 2018, 20:00
neftali.rosado, just an FYI for you in case you do not already know. If you are planning to place that console into the car where you show the repainted dash you will need to remove the shifter bezel and replace the shifter arm with one for a console.
neftali.rosado
#8
Post by neftali.rosado » 28 Apr 2018, 20:47
Yes, I do plan on putting it in the car. I was told all I needed is the shifter bucket and that the shifter arm is the same. Do you know if there is anything else I need mechanically? I have the harness rear light and all the other stuff.
CATHOUSE
#9
Post by CATHOUSE » 29 Apr 2018, 13:01
I am not aware that there is any difference with the shifter bucket. The shifter arm though is different. An arm for a console car will have a small loop tab at the base of the arm, this loop is not on a non console arm. You need this loop to connect the plastic linkage piece from the arm to the indicator light bracket. You should have an H shaped black plastic piece that holds the light to show what gear you are in. The linkage piece goes between this bracket and the shifter arm. Without seeing what all you do have I cannot say if you are missing anything. Posting a photo of the other console parts you have would help.
neftali.rosado
#10
Post by neftali.rosado » 29 Apr 2018, 17:14
Attached are pictures of what I have. I am waiting on rear lamp and selector rod. It does make sense now that you mention it. Before I ordered the the shifter bucket I asked if the shifter arms were the same and I was told that they were. Now I am not really sure what the difference is or what is needed. If someone can chime in after looking at pics and let me know what I need it would be greatly appreciated. I also have shifter bushings. Below is the question I asked and response.
Question - Hello, I am in the process of installing a center console in my 67. Will the non console stock shifter fit the Shifter Bucket needed for console or are the shifters different?
Response - yes, they are the same shifter arm.
Console Parts.jpg (41.83 KiB) Viewed 268 times
