Can I paint my wheels and make em look like this?
mo2872
Contact:
Re: Can I paint my wheels and make em look like this?
#31
Post by mo2872 » 04 May 2012, 08:41
If they are screw-in, the rim should be threaded, so I wouldn't think there'd be anything on the backside.
Of course, I could be all wet, and it's just made to LOOK screw-in.....
T3
Yup, that guy, the hooligan.
tmh
#32
Post by tmh » 04 May 2012, 08:52
Took a nut off and from the looks of it the nuts on the outside are holding the stems in place, I think the stem is inserted from the other side of the rim (the part inside the tire) and then the nut on this side holds it. So to get em off means separating the tire from the rim which I'd rather avoid. The hold air great currently. I just have this uneasy feeling that if I separate em they won't seal up perfect like they are now. Probably just being a wuss here.
'68 XR-7 J-Code C4, San Jose, Edelbrock 1406, PS, Front PDB, 8" rear 3.0, PS is leaky and sloppy, invisible fan shroud
'79 Bronco XLT 351m, C6, Edelbrock Performer 400 intake, Holley 6140, Howards cam, 4" suspension lift, 33x12.5x15 Duratracs, dana44 front and Ford 9" rear both 4.11 LSD, Warn hub locks, invisible fan shroud
'80 Suzuki GS750E 16V DOHC, looks about 6 months old
'13 Honda CR-V AWD
mo2872
Contact:
#33
Post by mo2872 » 04 May 2012, 09:09
Bummer, well, it was worth a shot.
T3
tmh
#34
Post by tmh » 04 May 2012, 09:23
Wheel #1 ready for prime...
Last I checked the humidity was at like 85%. So no idea when I'll actually get to priming. Hopefully the humidity is dropping as it warms up a bit. I'll wait until it's below 60% like the guy who wrote them words on the rattle can says to.
'13 Honda CR-V AWD
johnboy
#35
Post by johnboy » 04 May 2012, 09:44
a woodstove in the garage helps... :smoke:
68 XR7 J code madras blue/aqua
Proud Member of the Curbsters
rides are at https://www.motortopia.com/members/johnboy/mediapress/
I used to eat a lot of natural foods until I learned that most people die of natural causes.
tmh
#36
Post by tmh » 04 May 2012, 14:04
Humidity has been slowly dropping all day. Down to 65% now. Hopefully I'll still be awake by the time it hits 59%. I'm doing this so by-the-book.
'13 Honda CR-V AWD
1967 S Code
#37
Post by 1967 S Code » 04 May 2012, 18:41
tmh wrote:Humidity has been slowly dropping all day. Down to 65% now. Hopefully I'll still be awake by the time it hits 59%. I'm doing this so by-the-book.
Dot the i's and cross the t's. One mistake I have made is on the recoat time. Some rattle cans say recoat any time and others say within an hour or after two days. I missed that once on the two day and recoated the next day, the paint wrinkled. I had to wait till the paint fully cured and sand it back down then repaint :( . What a pain and waste of time that was. So read that fine print on the can and follow it close.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
tmh
#38
Post by tmh » 04 May 2012, 19:24
I read each can probably 5 times while I was doing the test run on the soda can, so I'm sure I'll read them 10 times as I'm actually doing the wheels.
I learned something today... When the temperature drops 20 degrees the humidity goes up a lot. Last I checked it was up to 85%. I have a really nasty feeling it's not going to drop low enough for days.
I've already started prep work toward replacing the fuel tank and lines, and adding the smash bar on my Bronco-- came as part of the deal, just wasn't installed. I'm also about to start watching lotsa videos and reading up on what rotors to buy and how to replace them.
I wish I was painting the wheels right now. But mother nature is giving me the thumbs down at the moment.
'13 Honda CR-V AWD
G68
Supporting Member
Supporting Member
#39
Post by G68 » 04 May 2012, 20:54
tmh wrote:I read each can probably 5 times while I was doing the test run on the soda can, so I'm sure I'll read them 10 times as I'm actually doing the wheels.
I am only a few hundred miles from you and the humidity has been friggin ridiculous today! :wall:
"I feel more like I do now than I did yesterday"
1968 Cougar 289 4V
2018 F-150 XLT Sport 5.0L Coyote
2017 Mustang (Sally) 2.3L 310 HP EcoBoost
tmh
#40
Post by tmh » 06 May 2012, 22:46
Humidity has been playing in the 80-90% range this whole time. Sucks!!!
On the bright side, I did manage not only to get the smash bar on my Bronco as I hoped, I also got the rear window working without replacing a single part. It ain't perfect, but it does indeed open and close now, with a little hesitation at the spot when the two arms are at the totally horizontal position. Maybe a little more grease in a couple spots and it'll be smooth as silk. Lol probably not, but having it working and actually being able to open and close the tailgate as a one-man job is really great. And it looks like the cat's gonna be out of commission for who knows how long, with this damn humidity.
'13 Honda CR-V AWD
