Seam sealer along cowl
halbey
Post by halbey » 11 May 2019, 08:50
I am wondering if I am supposed to fill the 1 inch by 1/4 inch vertical slot where the cowl meets the fender with seam sealer as shown in the middle of the attached photo. 1969 Cougar.
does the vertical slot in the middle need sealer?
Cougar Bill
Re: Seam sealer along cowl
Post by Cougar Bill » 12 May 2019, 13:13
The factory used a ball of sealer kind like modeling clay pushed up into the crack from the wheel side. Also in the front lower corners of the rad core support.
1970 XR-7 428 Ramair 4 speed (now under restoration)
1970 Eliminator Boss 302
1969 XR-7 428 R-code 4 speed
1969 Std. 428 R-code C-6
1969 XR-7 Convertible 351 AOD
1969 XR-7 Convertible 428 C6
1969 XR-7 351 5 speed "RestoMod" New 525Hp "pacemaker"
https://www.youtube.com/watch?v=SBkOzr7N13Y
1968 XR-7 302-4v 4 Speed (J-code) On the way to paint!!!
1967 XR-7 302 & AOD Green- Wife's Cat
www.cougarbill.com
Cougar Bill
Post by Cougar Bill » 13 May 2019, 07:01
here's a pic of a 68
I had posted this once. but it done disappeared into the inter abyss I guess
www.cougarbill.com
halbey
Post by halbey » 13 May 2019, 23:40
Thank you for the input. I was concerned that it may have provided drainage for water coming through the cowl.
Post by Mike_B_SVT » 14 May 2019, 12:53
halbey wrote:
13 May 2019, 23:40
Instead it provides a nice pocket for water, and promotes rusting >.<
halbey
Post by halbey » 14 May 2019, 21:50
So, would I be better off leaving it open to drain the resevoir behind the pinchweld?
catlover
Post by catlover » 15 May 2019, 07:37
I have a 69 Cougar and those are open on both sides, also 67&68 are different.
There is never time to do it right, but always time to do it over
67 Cougar restomod
69 Elim. 428 SCJ orange/ white
CCOA 7574
Cougar Bill
Post by Cougar Bill » Yesterday, 08:27
So, Since I posted a pic of a 68 & I have a few 69's, I went & took pics. The first pics are from a 69 XR-7 M code Detroit cat. The last (blue) is a double "R" code, looks like they did things a bit different in Cali....
www.cougarbill.com
