0F91G512239 Unrestored Comp Blue/Black
For two years the Eliminator roamed the streets looking for prey. Although you could get an engine available from Mercury in the Eliminator, the Cobra Jet 428 and Super Cobra Jet 428 were common under the hood. This was also the only Cougar to get the Boss 302. The Eliminator Registry is maintained by Dave Wyrwas.
allenman85
Re: 0F91G512239 Unrestored Comp Blue/Black
#21
Post by allenman85 » 20 Jun 2015, 13:52
Does it have a "Caution FAN" sticker? :)
I'd like to see some up close photos of bracket bolts such as the horn mounting... heads out towards the nose or inwards towards the firewall?
1970 Cougar. 351C/FMX/AC/PS/PB/Comp Green w/White Top, 3:00 open
Now: 622 HP, 351W w/AFR, solid roller, 418ci, C6, 3.50:1 posi, 3" Magnaflow SS exhaust
Frank Bowers
#22
Post by Frank Bowers » 20 Jun 2015, 14:45
Bracket bolts--Horn mounting, shock cover and other bolts were mounted according to the installer. If right handed on passenger side of car, mounted with nuts on inside, if left handed, nuts on outside etc. There is no protocol with the Mustang club of America because there was none at the factory. Been there, done that.
Frank
PS---No CAUTION FAN sticker. They were not used at the factory.
1967 S Code
#23
Post by 1967 S Code » 20 Jun 2015, 17:25
Well done Dave. That is a great Cougar. It is special to see one in this type of condition in photos but even better to see it in the videos. Thanks for sharing and enjoy your latest Cougar addition.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
Mike_B_SVT
#24
Post by Mike_B_SVT » 15 Jul 2015, 23:13
Got my MCACN email tonight, with Dave's Eliminator prominently featured! Are you going to take the car through thier Vintage Certification program? That would be so awesome to have a video of that (hint hint)!
http://www.mcacn.com/7152015.htm
Mike B.
CCOA # 9553
Cat Bites Man!
70b302cat
Supporting Member
Supporting Member
#25
Post by 70b302cat » 17 Sep 2015, 11:16
Here are the mufflers on the 10/13/1969 built B2 Eliminator. Things have been a little hectic lately but I will be adding more pictures and scans of the paperwork. I do plan to have the car at the East Coast Cougar Nationals next month as well as in Chicago in November.
Passenger side
Driver side
Dave
Eliminator Registrar eliminator@cougarclub.org
Mercury Cougar Eliminator Registry
CCOA # 7558
CCNE # 08
70 Convertible 351C 4V Close ratio
70 Cyclone Spoiler 429 SCJ 4 speed Drag Pak
70 Eliminator B302 4V Close ratio
70 Eliminator B302 4V Wide ratio Super Drag Pak Cat
70 Eliminator 428 SCJ 4 speed Drag Pak
85 Capri ASC McClaren 5.0 5 speed
70b302cat
Supporting Member
Supporting Member
#26
Post by 70b302cat » 17 Sep 2015, 11:29
The original owner had two build sheets that came with the car. I do not know where they were found. They are both tractor feed pages but they are different in that one is ~ 8 x 8 inches and one is ~ 8 x 11 inches. The only differences in what is on the pages is the rotation numbers. The 8 x 8 is rotation number 0639 which is also written on the radiator support and the other one is rotation number 0624. The rotation number on the buck tag is 503, so we know that there were at least 3 different rotation numbers assigned to this vehicle during production.
Build sheet short 0639
Build sheet long 0624
Dave
CCOA # 7558
CCNE # 08
70b302cat
Supporting Member
Supporting Member
#27
Post by 70b302cat » 18 Sep 2015, 11:16
The spare tire appears to have never been removed. As this car was built in October of 1969, it has what are commonly called the "no size" tire. The actual size of the tire "F70-14" is not called out in raised white letters. The belief is that the "sized" tires were not manufactured until January of 1970. There are 4 red paint daubs on the back of the tire as well as an inked arrow to the weight. On the front side there were two small squares of rubber that kept the tire from rubbing against the rivets on the jack, but stayed on the tire when I removed it as can be seen by the "Goodyear" lettering.
Dave
CCOA # 7558
CCNE # 08
Mike_B_SVT
#28
Post by Mike_B_SVT » 18 Sep 2015, 12:00
70b302cat wrote:The spare tire appears to have never been removed. ... On the front side there were two small squares of rubber that kept the tire from rubbing against the rivets on the jack, but stayed on the tire when I removed it as can be seen by the "Goodyear" lettering.
That is cool! I'm pretty sure I've seen those little blocks of rubber drifting around in trunks before. Always thought they were just stray junk. Probably came loose the first time the tires were pulled out and then ended up down in the nooks and crannies.
Also cool to see how they cut the hole in the trunk mat to accomodate the mounting bracket location for the staggered shock cars. My mat is pretty beat up, so it is nice seeing how it is supposed to / used to look :-)
Thanks for the great detail pics and info Dave!
*Also nice to see exactly what sort of Jack I should have in the trunk, since mine was built within days of yours :-)
Did you find any date or PN stamps on your Jack? Or handle?
Mike B.
CCOA # 9553
Cat Bites Man!
70b302cat
Supporting Member
Supporting Member
#29
Post by 70b302cat » 22 Nov 2015, 07:53
While at MCACN the car was filmed by Lou Costabile of "My Car Story". It has been posted on You Tube.
https://youtu.be/KBurFYzkHO8
Dave
CCOA # 7558
CCNE # 08
jcbingcougar
#30
Post by jcbingcougar » 22 Nov 2015, 09:22
Dave, congratulations on getting your car featured! What a great Cougar.
Jeff Bingaman
1970 Cougar
1956 Ford F100
1960 Dodge Phoenix
2017 Mustang GT Premium
2017 F150 Platinum
http://www.cascadecougarclub.com
