Sunroof cable ends
There were only 619 XR7-Gs built. They were built along side the Shelby Mustang, and were available with every engine and transmission offered in 1968, (except the 427). This was the first Cougar to be a part of the Hertz Rent a Racer program. If you have any information about these rare cats, this is the place to share. The XR7-G registry is maintained by Royce Peterson.
Zogman
Sunroof cable ends
Post by Zogman » 15 Jul 2018, 18:23
So I’m putting my sunroof assy together and it works almost perfectly. Without the panel installed, I’m teasting the motor and cable functions. If I send the cables to the fully open position, it stalls out about 6” into the close position. Gear and cable appear to be good. I remove the side rails and notice that both of the cable ends are in the turn section about to enter the side rail. I’m thinking it’s jamming in that position. So I look at the inventory of cables that I have in hand and notice 2 different cable ends. One type has a longer nub or leader. The longer ones are installed right now. Can the nub size make a difference? I’m thinking it’s not bending enough to enter cleanly in into the side rail. Here is a pic.
Thanks.
Zoli
70 XR7 Vert Eliminator Clone
(2) 68 Hertz XR7-G's (Red & Yeller)
68 XR7 J code Sunroof
67 plain jane
06 Z06 Daily driver
1968XR7G
Re: Sunroof cable ends
Post by 1968XR7G » 15 Jul 2018, 20:43
I would think that the cable on the left side in the picture could be binding up due to the style of the end. I would try two cable that are like the one on the right.
Scott
xr7g428
Post by xr7g428 » 16 Jul 2018, 11:17
Are you aligning the rear slide with the 5th screw from the front? It sounds like it is too far back or something.
Bill Basore, Editor / Publisher
Legendary Cougar Magazine
Currently in the Cat House
'67 XR7 GT 390 4 speed, AC, AM FM, Lime Frost Green
'68 XR7-G 428CJ C6, Tilt-Away, AM, Black Cherry
'68 XR7-G 390 4 speed, Sunroof, Cardinal Red
'68 XR7 GT-E 427 C6 AM Cardinal Red
'68 XR7 resto mod 351W, soon to be AOD, Black Cherry
Zogman
Post by Zogman » 16 Jul 2018, 14:07
Bill, I am not sure what you mean by aligning it with the 5th screw. As long as the cable are lined up with each other, what should it matter where it's lined up at? Is there a stop of some sorts that should be in the rail to not let it go back to far?
67 plain jane
06 Z06 Daily driver
xr7g428
Post by xr7g428 » 16 Jul 2018, 22:58
The starting position is at the 5th screw. That is straight out of the manual. I think you have them too far back. I think the ends may start out already past the bend so they don't have to go around it.
Zogman
Post by Zogman » 18 Jul 2018, 12:49
Bill, would you happen to have a pdf of the manual? I own the manual but I am unable to find it.
67 plain jane
06 Z06 Daily driver
xr7g428
Post by xr7g428 » 18 Jul 2018, 16:24
Check your email. It is a zip file due to size.
Post by Don Rush » 19 Jul 2018, 09:19
We also have the manual here...
https://secure.cougarpartscatalog.com/1 ... attribs=76
We are currently working on listing every item on a 71-3 sunroof, here is what we listed yesterday.
https://secure.cougarpartscatalog.com/m ... attribs=76
