Heat shield on the exhaust manifold
Caleb
#1
Post by Caleb » 16 Mar 2018, 18:55
Hi guys. I have a 1969 351w in the car. The heat shield on the exhaust manifold appears to be in very good shape so I don't want to wreck it. Is there any way to get it off without pulling the motor? Maybe I am being too gentle but it seems too tight. Thanks in advance
cougarrand
Re: Heat shield on the exhaust manifold
#2
Post by cougarrand » 16 Mar 2018, 19:55
Remove the left motor mount bolt. Use a board to protect the oil pan and a floor jack to tilt the engine a bit to give you enough room.
Randy Feuillerat
67 XR7 GT 390 4V
68 390 X code XR7
68 XR7-G 302 2V
70 XR7 Convt 351 2V
70 Eliminator 351 4V 4 speed
Caleb
#3
Post by Caleb » 16 Mar 2018, 20:41
Thank you. That worked great.
