Does Vertical Scope's hack affect CCC.com?
Tell us what you think! This forum is here to serve the Cougar hobby, we need your help to make it better.
MrEos
Contact:
#1
Post by MrEos » 25 Jun 2016, 13:05
Those who post on vertical scope sites (like mc.net) might want to change passwords used on other sites, including this one, if you use the same username, and especially if you use the same username and password here as there. More info on the breach is at http://www.verticalscope.com/about-us/n ... reach.html
To be clear - this site has not been hacked. But the hackers may have your credentials from vertical scope sites (including mc.net). If you use the same login credentials here, then they could access your profile.
To change your password here, go to the upper right side of the page where you will see your user name. Select "user control panel" from the drop-down menu, then select the "profile" tab, then the "edit account settings" menu option.
xr7g428
Site Admin
Site Admin
Contact:
Re: Does Vertical Scope's hack affect CCC.com?
#2
Post by xr7g428 » 25 Jun 2016, 16:05
Good advice Mr. Eos! We have not been hacked, and we don't run the same software.
I have been watching for any strange actions and so far nothing is a miss. If any one sees anything please let me know.
I am still waiting to hear exactly how Vertical Scope was hacked. I don't think it was individual site, I think this was more of an inside job.
Legendary Cougar Magazine
Currently in the Cat House
leonbray
Supporting Member
Supporting Member
#3
Post by leonbray » 25 Jun 2016, 17:04
You can check if they have your vertical scope data here
https://www.leakedsource.com/
Enter your username from MCN, select user name from the drop down and then hit search
Designed to be driven
zman
#4
Post by zman » 26 Jun 2016, 06:18
leonbray wrote:You can check if they have your vertical scope data here
What do you do if they have your data.
69 Cougar 351W 4V, FMX Auto, PS,PDB, AC
55 Ford 2dr Customline 302 4sp
18 Ford F150 Super Crew 4x4 5.0
2012 Ford Fusion SEL
97 Arctic Cat Cougar 550 L/C
99 Arctic Cat Jag 440
CatVert68
Contact:
#5
Post by CatVert68 » 26 Jun 2016, 08:42
zman wrote: What do you do if they have your data.
Change your passwords on other sites that used the same one as MC.net.
CCOA Member 8302
1968 Cougar XR-7 GT, Madras Blue & Parchment w/ Parchment vinyl top
1969 Corvette L-48 4-speed LeMans Blue over Bright Blue
