390 motor pics from a 69 needed
Cougar Bill
#1
Post by Cougar Bill » 15 Mar 2018, 09:06
I just got in a 69 Standard convert w/ a 390 and NO A/C. Due to the poor restoration, almost all the metal has been painted chrome/silver or black. The owner would like it back to original as possible, so I need correct pics of 1969 390 engine bay with out A/C.
Thanks!
Bill
1970 XR-7 428 Ramair 4 speed (now under restoration)
1970 Eliminator Boss 302
1969 XR-7 428 R-code 4 speed
1969 Std. 428 R-code C-6
1969 XR-7 Convertible 351 AOD
1969 XR-7 Convertible 428 C6
1969 XR-7 351 5 speed "RestoMod" New 525Hp "pacemaker"
https://www.youtube.com/watch?v=SBkOzr7N13Y
1968 XR-7 302-4v 4 Speed (J-code) On the way to paint!!!
1967 XR-7 302 & AOD Green- Wife's Cat
www.cougarbill.com
tinman
Re: 390 motor pics from a 69 needed
#2
Post by tinman » 15 Mar 2018, 11:09
There is a S code mustang registry here:
http://www.scoderegistry.com/
You can probably search for engine shots for a 69,Mustang and Cougar should look similar. Another option is the concourse mustang forum.
http://www.concoursmustang.com/forum/in ... 48d297b1c8&
Mike
J_Speegle
#3
Post by J_Speegle » 15 Mar 2018, 14:56
Do you have a Marti report for the car? There will be differences in the engine compartment depending on where it was assembled (the car)
Finishes for things like shock tower supports, hood latch support battery tray will be different as will other details outside of the engine compartment. Inspector marks or stickers as well as service decal locations differ also.
Also you will need to know if the car was ordered with the chrome package for the engine. At least for Mustangs it was an extra charge for the chrome valve covers and air cleaner lid.
In general 390 pictures are often difficult to locate since few were left in factory form and allot more attention has been given to its larger brother the CJ
Cougar Bill
#4
Post by Cougar Bill » 16 Mar 2018, 16:00
I do not have the Marti yet, Owner does has one.
Car is Detroit built. He has chrome "Mercury" valve covers and a GT air cleaner (no vac door). If you have any pics they can help!
Thanks!
www.cougarbill.com
J_Speegle
#5
Post by J_Speegle » 16 Mar 2018, 16:47
Cougar Bill wrote:
16 Mar 2018, 16:00
Thanks!
Not sure what a GT air cleaner is. Hopefully not one of those ones where the base has the screen door material in some cut outs. If so you'll be looking for an air cleaner based and possible a lid also since the 67 style air cleaner would not have passed the 69 federal emission standards and was not certified for cars delivered in the US .
Will find and put up some pictures from from unrestored examples and at least of the cars Mustang brother - they were all made at the same location and hopefully that will help
J_Speegle
#6
Post by J_Speegle » 17 Mar 2018, 14:52
Ok here are some pictures. As mentioned allot of these cars have been played with and things like heat shrouds (specific to 69 only) and S tubes have been removed over the years. Also since you were not specific to when the car was built don't copy other details shown since your car may have been built during a different period. Example would be the cowl finish above the pinchweld - painted engine compartment black or body color.
Three withe the chrome option as mentioned These first three are from another plant as your car so don't consider engine compartment details and sticker placement in you restoration ;)
Someone got carried away with the body and engine compartment paint ::) Don't copy the decal placement - especially the CAUTION FAN ;)
Plenty of service items on this one replaced over the years. Does show some details like the emission/timing decal placement
And another
Hope this helps
Cougar Bill
#7
Post by Cougar Bill » 19 Mar 2018, 10:40
What can be said except a "Thank you Sir"!
Great correct info & pics!
www.cougarbill.com
