Making functional ram air for 351
69XR7RestoMod
#1
Post by 69XR7RestoMod » 04 Feb 2018, 18:37
Has anyone here created a functional ram air setup like the 428 has on a 351w?
What parts would I need? I’ve already got the scoop mounted.
1969 XR-7 Restomod 408ci 483HP/523TQ, FiTech, TKO-600
DaveK
Re: Making functional ram air for 351
#2
Post by DaveK » 05 Feb 2018, 05:25
Probably just a seal for the air cleaner base to the hood and a lid just big enough to cover the air filter would be my guess.
1967 S Code
#3
Post by 1967 S Code » 05 Feb 2018, 06:31
Yes it’s been done by Bob on Isabel. Here is the link and a picture. You stated 351 but did not say Cleveland or Windsor. Bob has a Cleveland built to 408 ci.
viewtopic.php?f=2&t=640&p=7512&hilit
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
1967 S Code
#4
Post by 1967 S Code » 05 Feb 2018, 06:39
I missed the w in your post designating Windsor. I’m sure the same type of set up will work regardless of the engine type.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
R Code
Supporting Member
Supporting Member
#5
Post by R Code » 05 Feb 2018, 07:30
69XR7RestoMod wrote:
04 Feb 2018, 18:37
A hole in your hood, some garage door seal, and a lid that leaves the element exposed will work if you don't care how it looks & are OK with always drawing in outside air.
If you want it to function as the factory RA did (only drawing in outside air under full throttle), you'll need the RA air cleaner lid & vacuum-actuated flapper doohickey.
- Chris
1967 Std 4 speed conversion
1969 XR-7 "R Code" Convertible
1989 Merkur XR4Ti
cj750
#6
Post by cj750 » 07 Feb 2018, 15:18
Every post I make comes with a request for corrections. I'm here to learn.
1969 Cougar Eliminator 351 4V, yellow
1970 Cougar Eliminator 428SCJ, black
69XR7RestoMod
#7
Post by 69XR7RestoMod » 07 Feb 2018, 17:35
Nice! That looks great. All I need is a base now!
1969XR7Vert
#8
Post by 1969XR7Vert » 08 Feb 2018, 12:02
07 Feb 2018, 17:35
I used a stock 351W-2V base. Initially I used an (expensive) repro snorkel block-off (bought on ebay from Oz). That is what is shown in the picture Steven posted. Later, I removed the block-off, cut the lip from the snorkel cutout and butt welded in a plate made to fit the opening. Much cleaner looking and does not interfere with the garage door weatherstrip hood seal I use on my contraption.
frankie3555
Contact:
#9
Post by frankie3555 » 13 Feb 2018, 21:48
This is what I started just last weekend took some of Bob's idea's, I have the hipo air cleaner for the inside and Eliminator scoop arriving tomorrow.
canted 393
#10
Post by canted 393 » 14 Feb 2018, 06:08
Another option, http://www.fordramair.com/new/products/ ... _units.htm
He is pricey but very good quality.
