Wow, Up beat Cloth and vinyl 100% original paint 71 XR7
badcatt
Re: Wow, Up beat Cloth and vinyl 100% original paint 71 XR7
#91
Post by badcatt » 29 Jun 2017, 13:53
Wow, It has been about 4 months since I did an update. I have done a lot of work that I have not posted. The underside is just about done. That will be done next week as well as the below noted work in the engine compartment.
I spent some time on this project this week. I got 2 coats of Black primer on the engine compartment and then 3 coats of Semi Gloss Black on. Today I started putting parts back on. Engine frame stands, Battery tray and the brake lines reattached. My plan is to finish the areas under the hood hinges after I have the car on all 4 wheels. At that time I will remove the hood to clean and detail the underside of it and will remove the hinges then, I didn’t want to deal with that huge hood lying around in the shop for the last year.
Image[/url]
Image[/url]
Next week after the Fordnutz 50th Cougar show I will be hard at work to try and get this done by the Cascade Cougar Club’s 50th Cougar show.
Neal Jacobson.
1970 XR-7 White "Ginger"
1970 XR-7 Convertible Blue
1971 XR-7 Bright Blue with Blue "Up Beat" interior
See ya on the hiways,
they are an entire banquet
- Mark Twain -
badcatt
#92
Post by badcatt » 27 Dec 2017, 22:42
After a good 5 month hiatus I got back on to this project this week. We got the engine and transmission bolted in. I can now tinker around getting every thing hooked up and get it running, It will take ma maybe until March to get it all buttoned up. It will need to go to an alignment shop directly. Then get her all polished up for the summer. Some pictures below for your entertainment,
You will see more movement on this one over the next few months. I think I can see some light at the end of the tunnel...
Neal Jacobson.
- Mark Twain -
jcbingcougar
#93
Post by jcbingcougar » 28 Dec 2017, 08:04
Looking good! Glad to see you're making progress.
Jeff Bingaman
1970 Cougar
1956 Ford F100
1960 Dodge Phoenix
2017 Mustang GT Premium
2017 F150 Platinum
http://www.cascadecougarclub.com
ccarney69
#94
Post by ccarney69 » 28 Dec 2017, 20:02
Looks like it is coming together nicely, engine compartment looks great. Looking forward to seeing it on the road again.
1968 GT-E 427 Standard Nordic Blue/Black Décor, driver
1969 XR7 R Code 4 Speed Yellow/Black Top Black Interior, current project no.1
1969 XR7 Q Code C6 Green/Black Top Dark Ivy Green Interior, current project no. 2
CCOA #8275
MACC
1967 S Code
#95
Post by 1967 S Code » 29 Dec 2017, 05:17
The engine looks great in a fresh coat of paint. I’m looking forward to seeing your progress over the next couple of months.
Our Cougars
1967 Standard
Dan Gurney Special
1968 XR7-G
1968 XR7-G Hertz
Mike_B_SVT
#96
Post by Mike_B_SVT » 29 Dec 2017, 19:49
Wow, looks awesome! Can't wait to see it in person next summer :-)
Mike B.
CCOA # 9553
Cat Bites Man!
badcatt
#97
Post by badcatt » 04 Jan 2018, 22:01
I got back on the car today and got a lot of items done... Under the hood I got the carb, Distributor cap and wires, shock tower braces and some of the electrical installed under the hood.
I then raised it up and started working underneath. I got the mount bolts all torqued down and then went to do the torque converter nuts only to find out the original ones from the old converter are coarse threads and the new converter uses fine threads. So that is put off for a few days til I get to town next. So I moved on to the snifter linkage and kick down rod and the exhaust.
For the most part the exhaust went on nicely. But the muffler hanger on the drivers side has a problem. I had to move it inboard and at the moment it is only held on with nod bolt to the body. The other hole is about 1.5 inch outboard of where it should line up at. I will most likely have to remove that muffler and tail pipe to fix that. I don't know if the re-pop hangers are wrong or where I thought is went was wrong. The cross member had 2 holes that lined up with the hanger but did not have nut inserts. So I made a nut plats and welded it in to that location. The other side had a nut plate installed, but it has been installed on the upper side of the cross member before it was installed in the car. If you recall this had a single exhaust originally and I am upgrading it.
More in a few days. I am getting excited...
Neal Jacobson.
- Mark Twain -
fordnutz
Contact:
#98
Post by fordnutz » 05 Jan 2018, 01:28
Looking really nice Neal.
Thanks, Scott Ferguson
President, Fordnutz Cougar Club
E-mail President@Fordnutz.org
Visit the Fordnutz Cougar Club on the web http://www.fordnutz.org
Past Chairman, Cascade Cougar Club
http://www.CascadeCougarClub.com
Past Chairman, Cougar Club of America
http://www.cougarclub.org
CatsRock
#99
Post by CatsRock » 05 Jan 2018, 06:03
Looking good Neal i'm enjoying your progress :beerchug: Where did you get the exhaust set from ? The tail pipes on my phat cat are shot and the rest don't look much better so I figured I should replace everything while i'm at it :smoke:
08 Suburban
1973 XR7 351Q Vert
EX 1975 Cougar XR7
EX 1972 Cougar XR7 Vert
EX 1967 Cougar
badcatt
#100
Post by badcatt » 05 Jan 2018, 10:30
CatsRock wrote:
05 Jan 2018, 06:03
I had the H-pipe from a load of parts I bought a few years back. I got the rest from West Coast Classic Cougar. The hangers I got from Mustangs Unlimited.
Thanks for the positive feedback.
Neal Jacobson.
- Mark Twain -
