New 1157 "Plasma" LED Taillight Bulbs: Friggin' Bright!
Re: New 1157 "Plasma" LED Taillight Bulbs: Friggin' Bright!
Update:
What a moron I am. The brake light switch had come off and was not connected.
So almost everything works now. Had everything back in, all LED lights, LED sequencer, LED flashers (2). Everything worked except emergency flashers. Had to take out the yellow plasma LEDs out of the front turn signals and put the incandescence back in and the regular flasher can in the emergency flasher spot to get everything to work. I can live with that and am glad to have everything working great and BRIGHT!!!
69 XR7 San Jose built
Always under construction
Slightly improved 351W
CCOA member #9421
CCOA member #9421
New video featuring Richard (a.k.a. Mistress) on what's needed to convert your '69-'73 Cougar to the Plasma LED bulbs. Hopefully this clears some things up for some of you!
https://youtu.be/8Yuak3g-TcA
-Andrew Chenovick
Photo/Video guy for WEST COAST CLASSIC COUGAR, INC.
Side Gig: FLYING A PHOTOGRAPHY
RIDES:
-1968 Mercury Cougar: original family owned, Polar White, 289-2V, auto, AC / "Snowball" view project thread
-1973 Opel Manta: 1.9L, 5-speed (restored)
-1991 Mazda Miata: fun driver
-1992 Volvo 240 wagon: classy hauling machine
RIDES:
- 1967 S Code
- Registered Member
Great work and video guys. It seems that a lot of engineering went into figuring the LED system for each year Cougar.Blitz wrote:New video featuring Richard (a.k.a. Mistress) on what's needed to convert your '69-'73 Cougar to the Plasma LED bulbs. Hopefully this clears some things up for some of you!
Standard, 302 4V, XR7G Console, XR7G Front Valance, XR7S Taillight Bars
This was very informative. I just ordered 10 bulbs and what was said I needed to make it work. Now what about the head lights high and low beam upgrade? Do you have something for this? The only thing I have run across so far is the Xtravision H5006 Low beam and the H5001 high beam. What do you know and suggest?
Jeff Cumming with a 1973 Cougar
Had a 1971 Cougar XR7 in High School
So far we have yet to locate a 4 headlight system in LED that we like enough to promote. They will appear in time I think. These bulbs have earned us the most positive reviews of any product we have ever listed, check the reviews out here,Jailsey wrote: ↑10 Oct 2018, 17:48This was very informative. I just ordered 10 bulbs and what was said I needed to make it work. Now what about the head lights high and low beam upgrade? Do you have something for this? The only thing I have run across so far is the Xtravision H5006 Low beam and the H5001 high beam. What do you know and suggest?
https://secure.cougarpartscatalog.com/p ... attribs=76
We have a halogen headlight conversion kit that comes with a relay: https://secure.cougarpartscatalog.com/h ... ougar.htmlJailsey wrote: ↑10 Oct 2018, 17:48This was very informative. I just ordered 10 bulbs and what was said I needed to make it work. Now what about the head lights high and low beam upgrade? Do you have something for this? The only thing I have run across so far is the Xtravision H5006 Low beam and the H5001 high beam. What do you know and suggest?
-Andrew Chenovick
RIDES:
RIDES:
When I go to this site, The application does not say for my 1973 Cougar. Can you check it out and see if it will work or not? I already ordered the other outside Plasma replacement bulbs.
Do you make a complete interior upgrade Plasma bulb kit, including dome light?
Re: halogen headlight conversion kit
Oops, I posted the 67-68 version by mistake. 69-73 version is here. I think the main difference is the relay wiring. It's important to use a relay with halogen headlights in these old cars.
We don't have a kit for that because it just depends on how many of the bulbs you want to replace. You can do trunk lights and under hood lights too. Wherever there's enough room for tall bulbs, you can use the white 1156 plasma bulbs. For the instrument cluster, we have these. And here's an LED dome light for standard 71-73 coupes. The XR-7's didn't have the dome light, they had the C-pillar "Opera" lights instead. I'm not sure if the Plasma bulbs are too tall for those, but these would probably fit. Hope that helps!
-Andrew Chenovick
RIDES:
RIDES:
Do you have a halogen headlight conversion kit instillation video for wiring and relay placement for my 1973 Cougar. By the way, you are batting 1000 because I have ordered everything you have suggested. Thanks
Jeff Cumming
Jeff Cumming
