Check valves for a cheap skate :)
List your parts needs here! Please include your location and contact information.
pellets4fuel
#1
Post by pellets4fuel » 09 Nov 2018, 14:06
Looking for two working check valves I believe? Is there one that goes in the vac line from manifold to my A/C control tank reservoir and also one that goes in the line from manifold to the headlight reservoir tank. I think I have everything else I need. Send me a PM or post if you can help.
Thanks!
David Siedschlag
#16306 1967 Lime Frost S-code, Ivy gold interior built 11-1-66
3.25 Limited slip, 4-speed. Courtesy lights, sports console, whisper-aire, AM-8track, deluxe belts.
1989 Toyota truck, woodgas powered
22re 4x4
67429merc
Re: Check valves for a cheap skate :)
#2
Post by 67429merc » 09 Nov 2018, 14:11
Try rockauto, they are cheap!
67 standard(my first car) 428 4 speed
68 xr7
69 eliminator
70 eliminator
65 f100
70 mustang convertible
67 vw convertible
428cougarguy
#3
Post by 428cougarguy » 09 Nov 2018, 18:10
Yeah, those are the cheap blast plastic ones, they work, but not sure for how long. For used ones, more than 50% of them are bad, so if you happen to find an original one, most times it won't work properly. Unfortunately, the only good solution is to buy the new ones from West Coast. I know they aren't cheap, but they are correct.
