Window cranks
Window cranks
Have a set of 7 window cranks, set of 4 with decent black knobs, 3 without knobs, $50 lot
1970 COUGAR M CODE
Re: Window cranks
You do not have the required permissions to view the files attached to this post.
1970 COUGAR M CODE
Re: Window cranks
Hello
Do you still gave 71-73 window cranks? If so I’m looking for 4 short ones. Thanks
Re: Window cranks
I am not sure why you would want 4 short ones. From the factory they used the longer ones on the doors and the shorter ones for the quarter window. Plus you need to watch on the short ones as some attach with a center screw and some with a set screw on the side.
Re: Window cranks
The numbers on the back of the short one should be D2AB-7630323-AA. The reason I need 4 is two for the back seat the quarter windows and two for the front. The regular front ones hit my speaker covers. Hoping the short ones will correct that.
So I would be interested if they will fit a 72 Cougar. Thanks
Re: Window cranks
There are so many different types that don’t fit. I just want to make sure before I buy them. Thanks
Re: Window cranks
Pm me for payment. Thanks
Re: Window cranks
Hmmmm
Wonder if they will fit. What year car are they off off?
